- Feb 14, 2019
Hi all. Just joined this forum. I have a question on how to measure the blade edge thickness after bevel grind. I have tried using an Optical Comparator to measure the edge. I have tried using ground anvils that hold the bevel ground blade where the anvil contacts the flank angles of the blade. A fixed mounted micrometer can them measure the blade edge thickness a small distance from the actual edge. We trig out the thickness at that distance from the edge. I have tried using a go/nogo gap parallel bars too. Is there any specific gaging method that has a high repeatability value and is accurate enough to use that measured value in making process adjustments to the bevel grinder? I appreciate any thoughts.
