- Mar 10, 2013
I dont have any pictures ,but I copied the idea from old Pumas with stag scales that I had seen.
Price is $300 ea (shipped within CONUS). If you live outside the US, I will contact you after your order for extra shipping charges.
Yes. I make them on my lathe, and polish them by hand.Do you make cup punches yourself?
Darn! I don't know why I replied to it if it was that old!Bill, you do know this is a 10-year-old thread? Good info anyway.
caveman use big hammer,caveman take big swing,caveman hit hard.If you use the peen of the hammer, you will make yourself hit lightly in order to not smash the handle, this gives you the control to keep it on target. If you only have a flat surface to lay your handle/pin on, find a slightly rounded piece of metal (solid) and flatten one end (to rest on the "anvil"). Or if you have a railroad rail, the top may be curved enough to isolate just the pin. I epoxy first with temporary pins and once it is clamped and set for a few minutes, i remove the pins and wait for the handle to cure. Once done, I clear out the holes and use pins just over the size I want, glue and place. Once these are cured I start peening. Once one side is started, I flip over and see how much is on the other side and file it down if needed, then peen that side and switch back and forth till complete. You have to make a choice when to stop or you will crack your handle and get very annoyed.
