Joseph Bandeko
- Dec 9, 2021
Ok so I did a little searching and couldn’t find anything that gives a good method for this, so I’m going to tell what has worked for me and how I do it.
Keep in mind I am talking about PSA backed disks.
When you pull your disk off if there’s residue (I’ve even had most of the sticky film layer stay on, if that happens remove as much as you can with your fingers) turn the disk sander/grinder on and spray a thin layer of WD40 on the spinning disk (to much and it will just come flying off) and take a rage or paper towel (you can also spray WD40 on the rage) and press it against the the disk, keep doing this (you might have to apply a little more WD40 a couple more times depending on how bad it is) until all the residue is gone, this process only take’s like 30 seconds.
Then, again spray just a little bit more WD40 on and wipe off the excess, you want just enough on there so that the new disk barely sticks to the sander/grinder. (Once you start using it the PSA will get a better grip)
After that it shouldn’t leave much residue (if at all) when you take it of again, but if it does just follow the above instructions.
The above method has worked very nicely for me and is much more effective then anything else I’ve tried, including different kinds of solvents and heat.
