I live in Tucson, Arizona, which is pretty dry (not the driest place on earth but, definitely low humidity most of the year). I have several stag knives, which were acquired from the East coast. What I am noticing now, is that the stag slabs appear to be shrinking slightly.
If I stored them in a higher humidity environment (like my bathroom and the high humidity from the shower) would they return to their original size or, would this stress the stag too much?
The other option, as I see it, is to send the knives back to the maker and have them repolished. Normally, I would worry about this but, the sharp edges of the tang stick up about 1/32nd of inch and I dont want to cut my palm or fingers on the tang. I learned this lesson a long time ago using a Henckels Cleaver where the spine edges werent broken, causing me to split my thumb on my first relatively light use of the cleaver (a perfect 90 degree angle in steel can be very sharp .
My only real reservations about sending the knives back to have the tang and stag refitted would be the reverse effect if I moved back to Texas or Georgia at some point in my life.
Do I need to consider some sort of Stag maintenance like you do with leather to preserve it?
Thanks in advance for you help!
