I am looking for some feedback on Bark River vs. Dozier knives for hunting. Forgive me if this has been discussed in the past. I have found some discussion on this but not a lot. What are your thoughts on Bark River vs. Dozier knives in general and most specifically for hunting knives (primarily deer--gutting, skinning, processing)?
Also what model / models do you prefer of these brands as a deer hunting knife?
I currently own both brands and have owned both brands in the past and have mixed feelings on both. My thoughts / comments below:
DOZIER:
I owned a Professional Guide probably 20 years ago and liked it but did not keep it too long. I currently own a Slim Outdoorsman and a Professional Skinner which I just got. I processed a deer this weekend using both knives. I gutted, skinned and quartered the deer with the Pro Skinner. I did not find it ideal for gutting b/c I had a hard time splitting the rib cage open (which I like to do when field dressing). I also found that it was not ideal for cutting out the rectum / anus just because of the length and blade profile where a longer / skinnier blade does better.
For skinning it was okay, but not sure if I would rate it as any better than any other knife. Quartering it did well also but I don't know if it was superior to any other knife in this regard. I was impressed though that after all of this it was still sharp and had no edge deformation of any sort. After butchering the deer though the blade was no longer shaving sharp.
In terms of ergonomics I found the knife to be a bit chunky and not as precise as it could be.
I tried sharpening the blade this morning but have yet to get it truly hair popping sharp after a short time with a Spyderco Sharpmaker with diamond and ceramic sticks. I did not try for long, but usually this sharpener is effective pretty quickly.
BARK RIVER:
I have owned a couple and this year I used both a Gunny Hunter LT in 3V and a Fox River in 3V. I was not thrilled with the performance of the Gunny. I don't know that I prefer the blade design for deer. And after gutting, skinning and quatering a single deer I had some minor folding of the blade edge. A strop brought it back to shaving sharp, but the edge was still visually damaged. I was not expecting that from 3V and a convex edge.
With the Fox River I did the same on one deer and the edge was a bit nicked up after. I used a steel and then a strop and got it back to shaving sharp without any visual blade damage, but it took a long time, unlike other Bark River knives I have owned in 3V that were easy to sharpen. Additionally, I washed the blade and left on my counter wet for about 10 minutes and there was a permanent water stain from on of the water drops. I found this surprising from "3V" as well since I don't think it should stain this easily.
Based on the issues above with both of these two blades it makes me question the heat treatment of them, the edge geometry, and maybe even if they are truly 3V since I have read of there being issues with some knives being incorrectly marked / sold as 3V that were not.
COMPARISON AND TAKEAWAYS:
My initial thoughts: I can get the Bark Rivers sharper and then re-sharpen them easier. They do cut easier in this regard, but the edges seem fragile and I am unsure about the staining issue and quality of the steel and heat treat.
For the Doziers they seem better made and they had no issues with edge deformation or staining, but I don't know that I am going to be able to get them as sharp. Seems they are difficult to get shaving sharp or paper cutting sharp; however, maybe this is not an ultimate test of cutting ability. But I can say that in slicing up chunks of meat today the Bark River did slice and push cut slightly better than either Dozier.
I do believe that I probably don't prefer the blade design of the Pro Skinner, but that should not be the determing factor for all Dozier knives. I am considering a Yukon Pro Skinner or another model that may be a bit more controllable and svelte. The Slim Outdoorsman is very controllable.
Thoughts on these two brands and their models and / or feedback on my comments above? I have not yet decided which brand I prefer. I leaned toward Dozier based on quaity and reputation, but not being able to get them sharp may be an issue and a deal breaker.
Matt
DOZIER:
BARK RIVER:
Matt
