weo
Basic Member
- Sep 21, 2014
FYI - from a machinist perspective (FYI - I'm not a 'real' machinist, I just play one in real life
), to maximize life of all metal shop tools, you need to match speeds and feeds for the machine, task and stock size. For mild or annealed steels, a good starting point for drill press RPM is 240/bit size. So for a 1/2" hole, 480 RPM should be good.
Also, don't forget that cutting fluid is there for cooling the bit, (not to lubricate the bit, like I hear so often. Don't forget, we are trying to get the bit to cut, not slide) so use only as much as needed. For 1/2" holes or larger, I often peck drill, allowing the bit to cool in the air while drilling. If you pay attention, you don't even need cutting fluid (saves a lot on clean up).
