Edit: This is the first knife that technically meets my criteria I've found but I'm unsure how strong it would be (joint, lock, and metal) https://sogknives.com/kilowatt/#tech-specs
I thought I had it figured out but alas now that it's getting colder and with the hand damage my current knife is a pita to hold. I want a curve at BOTH ends of the grip to help push/pull it fast.
Basically I want a single edge fixed blade that has a joint in it. That ideally has some level of finger grooves to really hold on when I'm in ice/snow/carpal tunnel flares up again. Then I'd want a sheath to carry it open. AIWB left side. 10 ish degrees away from horizontal.
I really liked the grip on my benchmade nimravus wish I'd gotten to keep it (even if it won't suit the needs here)
A really solid 3 or 3.5" knife with removable grip scales that I could get a sufficient grip for might suit me well too.
Thoughts?
Basically a grip like this but a folder that I"d then carry open https://amtacblades.com/the-minuteman/
Another good grippy fixed blade https://headhunterblades.com/collections/headhunter-blades-all/products/weapon-rat-training-package
Be even better if I could get a blue trainer too.
Thoughts?
