Actually, all SK steels have same ammount of impurities.
Hitachi makes a number of carbon steels. Here are the common ones found in knives.
SK Steels (sk5, sk4, sk3)- the least expensive of the carbon steels and the lowest carbon content (#5 has the least carbon, #3 the most). This steel has higher amounts of phosphorus and sulfur than the other steels i'm about to mention. This steel tends to be tough (due to the lower carbon content and thus lower hardness). It also tends to be more reactive.
Yellow Steel (yellow 3, yellow 2)- This steel is more pure (less phosphorus and sulfur than the SK Steels). It also has higher carbon content (#3 has less carbon than #2 in this case as well). This steel is commonly found in saws and wood working tools. It is also sometimes found in knives.
White Steel (White 3, white 2, white #1)- This steel is even more pure than yellow steel (which is relatively pure). Once again, the lower the number, the higher the carbon content, so white #1 has the most carbon and white #3 has the least. The higher carbon (and hardness) leads to white #1 having the best edge retention of the white steels and also the best ability to hold an acute angle. White #3 has the best toughness.
