Cliff Stamp
BANNED
- Oct 5, 1998
I picked up a large drop point Twistmaster from Cold Steel awhile ago mainly because it seemed to me that the lock design was in
theory very secure and strong. If you combine that with a blade of the necessary size for even the larger cutting tasks, while at
the same time a high performance full flat grind and excellent edge curvature, it seemed to me to have a lot of promise as an EDC,
heavy use folder. Now of course, it would always be better to have a fixed blade, however I simply would be able to carry a
folder, even one such as large as this, more often than a fixed blade. This restriction is not because of legal issues, but just
that people tend to react a little less to a folding knife. It is not the ideal solution, but sometimes you have to compromise, I
can't carry my Battle Mistress comfortably at work.
After taking the knife out of the box I was hit with its size. I expected a large folder, but this knife is really big. It dwarfs
my Swiss Army Rucksack for example which is not a small knife. The Twistmaster is light, it only weighs 120g, but when open it is
27.5 cm long. Even folded it is 15 cm in length, and thus will readily stick out of your pocket. The edge length is 11.5 cm, but
because of the curvature you gain another cm, thus producing a total working edge that is 12.5 cm long, which is a lot of blade
for a folder. The extreme edge curvature produces a sweep of about 10 degrees down from the choil, and up towards the tip. The
handle is swelled very well in both axis, it has a 0.5 cm taper across the back, and a lighter taper vertically. It fits well in
hand, however the aggressive checkering, while no doubt very secure, will be abrasive. There is no need however for the blade
cut out in the handle to have its edges as square as they are.
At a casual inspection I was very pleased with the geometry as it promised very high performance cutting. The edge is highly
polished and will push shave hair with both sides. The blade can also be pulled smoothly right through a sheet of photocopy paper.
However it did not have that blistering sharp feel that an optimally polished blade will have. Verification came with some light
thread cutting. The Twistmaster required between 80 and 150 g to cut through the light thread with a median performance of 110 +/-
13. This confirms the feel, while quite sharp, is a little uneven and could be 10-15% better. Testing the slicing performance on
1/4" poly revealed a lack of aggression with a 500 g load, 3.1 +/- 0.4 cm of edge was required to cut the cord. However with a
1000 g load the blade sheared nicely through the poly only needing 0.50 +/- 0.05 cm of edge.
Moving on past sharpness I checked the blade geometry in some detail. The blade stock is 1/8" with a distal taper with a full
flat primary grind of about 2.1 +/- 0.2 degrees, which tapers to a very thin and acute edge. The edge starts off with an angle of
about 16 degrees near the choil, it sweeps own to about 13 degrees near the middle and then back up to about 18 degrees as it runs
towards the tip. Behind the edge the blade is decently thin, near the choil 0.022", towards the middle 0.12" (excellent), and near
the tip it thickens again to 0.21" . It is an interesting profile, you have maximum cutting ability across the middle of the blade
with the tip and the base of the blade reinforced for very heavy cutting.
To quantify the cutting ability some stock testing was performed. First off I cut points on one inch hardwood dowel. The
Twistmaster bit into the wood very strongly. Six points were made in all on different dowels and the results were very consistent,
the knife took 12.2 +/- 0.8 cuts to complete the point, very high performance indeed. This is not surprising given the very high
performance edge geometry and the fact that the edge starts only 1.5 cm in front of my index finger, thus the leverage is very
high. Using a rocking push cut on 3/8" poly, I was very pleased by which the blade so easily severed the rope, it bit in deeply
almost immediately and made a complete cut requiring only 37.0 +/- 0.9 lbs of force.
Did this cutting dull the blade? Yes, but only slightly. The thread cutting showed a little decrease, the blade now required 147
+/- 15 g to cut the thread, this was test along the area that saw the most cutting. The 1/4" poly under a 1000 g load now need 1.3
+/- 0.2 cm of edge to make the cut. A simple shaving tested confirmed that the blunting was do to edge rolling, which was not
surprising considering the dowel cuts were all made on one side of the blade under a high load (about 75 lbs). To bring the blade
back to optimal performance I spent some time on a leather hone loaded with CrO buffing compound. Twenty passes were made
alongside both sides of the blade which removed the fold in the edge. The blade now sheared through the 1/4" poly under the 1000 g
load only needing 0.30 +/- 0.05 cm of edge, this was better than the NIB performance.
Ok, so the cutting ability is very high. Are there any problems? Yes. First off the action of the blade is *very* stiff. If I put
a little oil on the blade it is near impossible to pinch it tight enough to draw and the nail nick actually exerts enough load to
make it a little uncomfortable. To be a little more precise, it takes about 14.8 +/- 0.5 in.lbs of torque to actually pivot the
blade out of the handle. Closing it is a little easier, it only needs about 7 in.lbs of torque to collapse. The locking ring is
also very difficult to turn, a little lubricant on it and it is near impossible to lock or unlock. Even when cleaned it is easily
possible to jam solid if you over tighten when locking and with some use it becomes near impossible to release. On the positive,
the locking ring has an angled cutout which should act as a mechanism to counter act wear, it could be cut similar on the bottom
to lock the blade in the handle.
On the positive, the lock is very secure and has no problems with spine whacks, white knuckling or torquing. The only way to
induce an accidental release would be if your hand ramped up on the blade on a deep thrust and then you torqued on the handle thus
moving the locking ring. However given how difficult the locking ring is to move, I don't see this as very possible, so I would
judge the lock as among the most stable I have seen. However in regards to raw strength it appears really weak. The locking ring
is only 0.02" thick and would thus readily be compacted. The back stop of the blade also rests against just the plastic handle and
thus it would also get damaged if the blade was to see impacts. In regards to lateral stress, again it is just plastic holding
the blade in place, I don't see much effort required to put serious play in the blade.
My main problem with the knife is the lock of coherent design. You have a very large blade of decent thickness with a lock that
sacrifices ease of opening and closing for security and strength. This implies a knife that is designed for serious heavy use.
However the very low strength of the lock and the fact that the main strength of the body depends on just hard plastic really only
makes it suitable for low stress cutting. On the positive, this knife could be made very strong and dependable with just a few
minor modifications. If a much thicker and stronger locking ring was used as well as a steel backstop for the blade, the strength
increase would be incredible and the folder might actually be a decent replacement for a fixed blade.
I was going to take this blade apart after a brief inspection told me that it didn't have the strength in the lock that I wanted
for a folder of this size, however after discussing some work with Jimbo, I didn't feel it was necessary, and a friend expressed
interest in the knife so I will give it to him after using it for a few weeks to see if I missed anything performance wise. Jimbo
also has some commentary about this knife which is worth reading :
http://www.geocities.com/Yosemite/Rapids/5404/survival/tm.html
-Cliff
-Cliff
