Price is $300 ea (shipped within CONUS). If you live outside the US, I will contact you after your order for extra shipping charges.
Depends on what you hope to achieve with the strop. If you're just looking to clean up some light burrs from your edge, or gently re-align a rolled wire edge, a bare strop can work just fine. If your goal is to further refine, hone and/or polish the bevels, some compound would be a good idea. All of this depends on the edge being ready for stropping, too. If the edge isn't very sharp to begin with, or not fully apexed, a strop of any configuration probably won't help too much, with compound or not. Most of the real work needs to be done on the stones first, and stropping shouldn't take more than maybe 10-20 passes (or less) to really make the final edge 'pop'.
With respect, I have to clarify a point you made here...
Stitchawl
A 'bare' strop still hones and polishes an edge. It just does it at a much finer grit size than when some other compound is applied. Most people are using Chromiun Oxide (.5mic) as their 'finishing' compound. Those wishing to go further use a diamond compound at .25mic. A bare leather strop's natural silicates are around .05mic and smaller, which is why it gives such a sharp finished product. BUT.... you really won't get the full benefits of that unless you already have worked down to a proper starting point before going to the bare strop. Without taking the edge down first, yes... a bare strop will function to clean up some light burrs from your edge, or gently re-align a rolled wire edge, and will do it very well, as will denim, your palm, or your shirt sleeve. But if you progress down through the grit sizes and THEN go to the bare leather strop, you will see a major difference very quickly. It will produce an unbelievable edge!
Stitchawl
I know this. It just does it much, much more slowly, and at a degree that'll only be noticeable if the edge is already pretty refined. ... Whether a compoundis 'necessary' becomes glaringly important if the edge isn't ready for bare-leather stropping, which is where something more aggressive will help.
All the more reason to practice stone work and get the edge as refined as possible coming off of the stones, in my opinion. Improving my stone work and getting results on bare leather has been a huge sharpening revelation for me.
(...)All of this depends on the edge being ready for stropping, too. If the edge isn't very sharp to begin with, or not fully apexed, a strop of any configuration probably won't help too much, with compound or not. Most of the real work needs to be done on the stones first, and stropping shouldn't take more than maybe 10-20 passes (or less) to really make the final edge 'pop'.
Stitchawl
I know this. It just does it much, much more slowly, and at a degree that'll only be noticeable if the edge is already pretty refined. And even slower with steels that might be more abrasion-resistant than what the silicates in the leather can polish/abrade effectively. That's the point I was emphasizing in my post. Whether a compound is 'necessary' becomes glaringly important if the edge isn't ready for bare-leather stropping, which is where something more aggressive will help.
Hi stitchawl,
Is there a reference where I can read about the size of silicates in leather? This is pretty interesting! I would love to read up on how it was measured.
Some stropping compounds go down to 0.025 microns.
http://www.chefknivestogo.com/25namepodisp.html
The natural silicates in leather are reported to be sized from 0.1 down to 0.01. (Whether these reports are accurate or not is anyone's guess.) But, if correct, the horsehide strop is taking me down to about the same level as the $60-a-bottle stuff in your link, and it never runs out...
Stitchawl
(from site -->: http://en.wikipedia.org/wiki/Biogenic_silica )
"Biogenic silica (BSi), also referred to as opal, biogenic opal, or amorphous opaline silica, forms one of the most widespread biogenic minerals. Silica is an amorphous metal oxide formed by complex inorganic polymerization processes. This is opposed to the other major biogenic minerals, comprising carbonate and phosphate, which occur in nature as crystalline iono-covalent solids (e.g. salts) whose precipitation is dictated by solubility equilibria.[1] Chemically, BSi is hydrated silica (SiO2·nH2O), which is essential to many plants and animals.
(from site -->: http://en.wikipedia.org/wiki/Biogenic_silica ):
"Diatoms in both fresh and salt water extract silica from the water to use as a component of their cell walls. Likewise, some holoplanktonic protozoa (Radiolaria), some sponges, and some plants (leaf phytoliths) use silicon as a structural material. Silicon is known to be required by chicks and rats for growth and skeletal development. Silicon is in human connective tissues, bones, teeth, skin, eyes, glands and organs."
(from site -->: http://en.wikipedia.org/wiki/Phytolith )
"First, soluble silica, also called monosilicic acid, is taken up from the soil when plant roots absorb groundwater. From there, it is carried to other plant organs by the xylem. By an unknown mechanism, which appears to be linked to genetics and metabolism, some of the silica is then laid down in the plant as silicon dioxide. This biological mechanism does not appear to be limited to specific plant structures, as some plants have been found with silica in their reproductive and sub-surface organs."
(from site -->: http://en.wikipedia.org/wiki/Cell_wall )
" Secondary walls - especially in grasses - may also contain microscopic silica crystals, which may strengthen the wall and protect it from herbivores."
Well, maybe?I don't have that much experience with stropping, and I don't have any fancy microscopes, so I don't know. But _in theory_ one might wonder:
(1) Do the diamond abrasive would work much faster than silicate particles? (Verhoeven's results suggest that plain leather has relatively little effect, but that's for his technique and leather.)
(2) Do the silicate particles eventually wear out (ie: break down too much and/or the particles become too smooth)? What is the hardness of silica particles versus modern knife steels?
(3) Are silicates just below the leather surface able to migrate to the surface? (Maybe the mechanical compression/decomperssion during stropping allows migration of silicates?)
I'm curious also, about finding the 'scoop' on natural silicates in leather. In very vague terms, I think it comes down to how the natural silicates in the earth's crust (many or most from remains of ancient sea organisms) are absorbed/metabolized into plant matter (cell walls), then the plant matter is consumed by grazing animals (cattle, horses), and the natural silica is then metabolized/absorbed into the connective tissue of the animals' skin. The size of the silicates, I'd assume, would therefore be limited by the thickness of the plant cell walls into which they were absorbed or metabolized. This is what I think I understand from what I've read,
I know almost nothing about tanning... But apparently some silicates (specifically sodium silicate) are used in tanning?
