Cliff Stamp
BANNED
- Oct 5, 1998
This is an email I sent to Bill which he suggested might be of interest here so:
<blockquote>
My brother was using the 15" Ang Khola while he was doing some climbing and
he did not have it strapped on that securely and he managed to knock it
loose and it tumbled down the side of the rock face. Surprisingly it did not
come out of the sheath nor did the sheath get damaged (except for a few
scrapes). Anyway the total sum of the damage was that the buttcap loosened
up a bit do that it could be jiggled.
He returns it to me so I could have a look at it. I took it out and did some
work to see if the handle had any security problems. After about 15 mins I
was convinced that it didn't but I didn't like the jiggling so I decided to
fix it. I went and got a decent epoxy and basically smeared it around the
buttcap going up over the brass. ( This had the nice side effect of actually
making it more comfortable to carry as it was not as pointed. )
After it dried I wanted to test it out before I gave it back to him so I
went for a walk. I soon found what I was looking for and that was a tree
about 4" in radius that had cracked off (windblown). For the first test I
finished cutting it down. Slight workout but the handle held fine. Now for
some serious testing I set the blade into the exposed stump and pulled
sideways. Since this was fresh wood it would not split but the khukuri would
just eventually force the wood a bit apart and then pop free. I started out
light just setting it deep enough that I could pop it free with one arm,
then two, then finally I was leaning on it. At this stage the khukuri is
being set pretty deep into the wood and I am leaning pretty hard on it.
At this time I have probably been this sort of prying for about 5 mins and I
am not really looking that closely at what I am doing. Its just like chop,
push, out pops the khukuri and repeat. I give it another smack and lean to
the side when all of a sudden I hear a loud *CRACK*. I glance down and I
have split a fairly large piece of the log off.
Now I know I should know better by now but just for a split second Bill I
was sure I had mangled the handle
</blockquote>
-Cliff
<blockquote>
</blockquote>
-Cliff
