Some final thoughts...
Testing
Re the edge--
Outside of what obviously happened with the square washer, far and away, the frozen elk antler beam was the most difficult media to get through. Remember that the knife was frozen solid too when that test was done. I thought for sure that test would break something, sort of the irresistible force (knife) vs the immovable object (elk antler). Progress through the antler was very slow. Thank goodness for the sledge because had I tried that with a hammer, I'd still be there today. In the end, the frozen knife beat the frozen elk antler, and it faired very well in doing so I might add.
Re the tip--
A lot of folks end up sticking the tip of a knife through some piece of car. While cool looking, I thought the steel flat that I pounded the knife through was much more difficult for the tip. IIRC, I think I have seen video where someone could actually penetrate a door of a car with the tip of a knife using just the force of their swing. I would be shocked if anyone was strong enough to be able to do that with the steel flat I used. I really don't think someone could.
I also thought about throwing the knife tip first into wood. The reason I opted to not do that was that it just seemed too random. On some throws, the tip might not be the first thing to strike the wood or it might strike it at an angle. My giant dead Eucalyptus stump also had a lot of rocks and rocky soil around its base. I did not want the knife to bounce off the tree only to fall, hit a rock and get damaged that way. So instead, I opted to drop the knife onto its tip from 7' instead. Easier to do, repeatable and consistent, and much more controlled, and probably much harder on the tip since it was hitting concrete type media. It may have been hard to see on the video, but in person, I can tell you that the tip hit first and solidly on every drop.
Lessons Learned
Nathan's explanation about what happened to the edge as I attempted to pound the knife through that square washer makes perfect sense. It helps me (heck, all of us) to better understand what really happened that was too fast for the camera to capture. Thanks for that explanation, Nathan. :thumbup:
The handle was very comfortable. I intentionally wore no gloves because I wanted to get some feedback from holding the knife while pounding on it. IMO, the handle is perfect for my hands, which are medium/large in size. I had no hotspots or blisters whatsoever. (The wood baton was not so kind, however.) The micarta is very tough, strong, and abrasion resistant. I could not dent it or chip it, only break it in half.
Honestly, I was not expecting the knife to last nearly as long as it did. I have seen many tip and edge destruction videos/images with many different knives, both production and custom. The tip and edge both lasted much longer than I thought they would have. Hype and extreme performance are commonplace in the knife industry, but this knife truly delivered. It does not look indestructible or bad@ss, but its ability to remain sharp, useful, and intact in the face of overwhelming destructive forces is nothing short of remarkable. The "Honey Badger" or "Wolverine" would have been a very apt name for this knife. It just didn't seem to flinch at most of what I threw at it and it was capable of handling things that many knives would not stand a chance of handling.
The knife is an excellent "all-arounder". It stayed very sharp for a long time, was easy to sharpen once dull, was obviously very strong, and was just a real pleasure to use. I think the design of the knife was very well thought out as was the ultimate choice of materials to use, heat treat of the steel, and the size and profile of the knife. I'd probably square the spine up a tad to make work with a firesteel a bit easier, but that is an easy fix.
Finally, a very big "Thank You"...
I want to recognize and thank rodriguez7 for providing the elk antler used in the test. He sent it on his own dime as well. Without his generosity and effort, there would have likely been no such test as I don't really have access to elk sheds. Thank you and best of luck in your remaining hunts this year. :thumbup:
Thanks to Nathan for his willingness to send me a knife for destruction. It was a hell of a lot of work, but I found it rewarding as well. I think we all can learn at least something from the video, but having gone through the process personally, I think I have an even greater appreciation of what this knife can do. To that end, I would encourage anybody to jump into the fray if they ever have the opportunity to do what I did with this knife. It was a great learning experience and I don't think you would regret it.
If anyone has any further questions or concerns, feel free to hit me up by PM or ask them here. I am happy to answer whatever I can. :thumbup:
