Utility knives measuring 6 - 7 inches are called petit gyuto. ... Generally, stiff boning knives are better suited to boning red meats, whereas flexible boning knives may be used to fillet fish. In Japan, a triangular boning knife called a honesuki is used for boning chicken and red meats.Traditional Japanese knives are characterized by its single-bevel blade, a sharpened edge on one side of the blade surface and the other side completely straight. ... Western knives, on the other hand, are double-beveled. Most double-beveled blades have a V-shaped blade edge.
I'm afraid you've posted quite a number of errors.
-Utility knives measuring 6 - 7 inches are called petit gyuto. ...
They are called Petty Knives in both English and Japanese. The blade length normally ranges from 120mm/4.72in to 150mm/5.9in, although there are a couple of models that go to 180mm/7.08. They are differentiated from Gyutos not just by their blade length but their lower blade height. They are never called "petite gyuto".
-Generally, stiff boning knives are better suited to boning red meats, whereas flexible boning knives may be used to fillet fish.
There are
no flexible Japanese knives at all, boning or otherwise. Fish are filleted with a Deba, which is not flexible.
-In Japan, a triangular boning knife called a honesuki is used for boning chicken and red meats.
A Honesuki, made for chicken, and it's larger version the Garasuki are dedicated knives used only by professionals.
-Traditional Japanese knives are characterized by its single-bevel blade, a sharpened edge on one side of the blade surface and the other side completely straight. ...
The flat side of a traditional single bevel Japanese knife
is not completely straight. It is called the Urasaki (or Ura) and is actually concave. It is not a perfect chisel grind. Therefore actually require sharpening on both sides.
-Western knives, on the other hand, are double-beveled. Most double-beveled blades have a V-shaped blade edge.
99% of Gyutos (chef knives) are double bevel. But there do exist single bevel Gyutos.
Nakiris are traditional Japanese vegetable knives and all double beveled. When they are single beveled they are called Usuba.
