Hi I got a Ka-Bar Dozier and I tried to loosen the pivot screw but when I turn it the other side moves also. I can't grab the part on the other side of the knife with anything and it is pretty tight.. What should I do to loosen it?
If your not to worried about how it looks may be put a couple of drops of super glue on the pivot to stop it turnimg.clean it up when your finished.Just a tought!!
Unless the blade is clamped tight between the liners. (you wouldn't be able to open the blade much at all) Then it's loctited, simplest method is a soldering iron stuck on the screw head for awhile until it heats the loctite enough to weaken it, then it SHOULD be relatively easy to pop the screw out.
