Yeah it will be a little bit of a pain but wouldn't be too terrible since it's already set. What grit would you think about going back to? Maybe the 140 XC?You're best bet is going to be going back to down in grit and reset your main bevel completely. Which yes is going to be a pain. This time make sure that it is easily slicing paper and the hairs are popping off your arm before you move up from the 300 grit.
This reminds me. Are you finishing each stone with a stroke pattern on 6,5,4,3,2,1 per side using only upward passes?
The fine Arkansas should also refine your edge further. Is it a black or translucent? You have to be careful when transitioning between the diamonds and the Arkansas because they are a different thickness and this will change the angle.
As for microbevels if you ask 10 people you'll get 15 different answers haha many only use 2 or 3 strokes per side on the highest grit they have. With all techniques I think the key is light pressure and upward strokes only. For me I do it one of 2 ways.
Most knives I use only the 600 grit hone and do 5,4,3,2,1 up strokes per side. Gives a slightly toothy edge that will cut anything you'll ever need it to for a long time. And don't get me wrong it's still plenty sharp. It will easily slice phone book paper.
The second way I do it I set it up the the same way and use the same pattern as the first one except this time I start with the 1500 grit diamond then move to the black fine Arkansas and lastly I'll take it off the clamp and finish with a few passes on a stropman strop loaded with his green compound
Sent from my SM-G930V using Tapatalk
You do want a burr on the "base layer"... but you don't want to do it with the 50g stone, because it's so aggressive it will leave large chips in the edge that you'll have to grind out with the finer stones. Save the 50g stone for larger work (lowering the angle or grinding in a new bevel for example). When you see the scratches of that stone just starting to reach the edge, switch to the next higher stone.
If you''re having trouble telling whether or not you have a burr... try marking the edge with a Sharpie and check and see if you're reaching the edge. Not sure what you mean by "rolling the tip"... are you grinding the point off? If so, just never let the stone go more than half its width across the tip... that should keep it from rotating around and grinding it off.
The bevel toward the tip may be a little wider, since on most knives as the edge curves toward the tip it also goes into thicker metal. Many manufacturers compensate for this by raising the angle as they approach the tip... so when you put it on a guided system, you'll notice the difference. However, you don't set the blade so that the heel and the tip are the "same distance". In most cases, you'll want the tip closer because the angle doesn't change on the straight part, it changes on the curve of the belly toward the tip... so you set the knife based on the belly/tip area. See this LINK for more info.
This just means your stones aren't fully broken in yet. I had the exact same problem at first going from the 600 to the 1500 and it took the 1500 a very very long time to break in compared to the others. I actually took an old piece of steel and rounded off an edge with a grinder and then while I was watching TV or something I'd use the 1500 grit on it and eventually it broke in. I was the same way though. I actually contacted Ron over at kme I was so convinced the grits were wrong haha but here's one of my first knives after breaking the stones in. It's only gotten better
Also I know they're not my knives but I'd highly recommend finding some old kitchen knives or cheap Walmart knives to practice on before starting on anything worth any money
I don't have the best pictures but in these if you can tell the ones with the tip to the left is the 300 and tip to the right is the 1500.
