- Feb 28, 2002
Well, Here is my sixth knife. O1 steel, 3/16" thick. 9-1/2" overall- 4 5/8" blade. The handle is stabilized black ash, with a reindeer antler section and nickel and black spacers.
This one went real smooth until I did the last step putting an edge on. Needless to stay, it did not go well. Nervous as hell, I reground the hollow section, starting with a 180 belt. One pass cool the blade, etc up to polish and a new edge a scary process.
I made 20 blades after my last (the fifth knife) . I kept 10 and this is the first of that bunch I have put a handle on. The remainder are 01 and 440C. Im getting more comfortable with grind, heat treat , finish and handle work.
Im still a bit perplexed about this "scary sharp" obessesion I keep reading about it has almost caused me to ruin more than one knife. On all my finish knives and test knives to date (all of 01 steel) I can get a respectable edge that will hold up, cut everything, do the brass rod test, etc and sometimes shave hair (which seem to be the measure everyone gets hung up one), but I suspect I dont have "it" with the sharpness based on what I hear on the forums. On the other hand, I test all my knives cutting ability beside a Randall Model 8. It wont cut hair, but I like the way it performs.
I have tried old belts, new belts, stopping at 220, 400, 600, knocking the wire off with a couple light passes on the buffer. The results do not seem to differ greatly. I temper with two draws at 375, separated by 24 hours in the freezer. I cant think of any other variables (I am also careful not to overheat when grinding the tempered blade) other than to how the results differ with the other steels I will be trying.
Bottom line, Id like to be able to sell a couple blades later this year, but Im getting nervous about meeting all the "requirements".
Bob
http://www.southrivermodelworks.com/page12a.html
Bob
