You can't get a definite answer because the width of a sharp apex varies quite a bit, say from 0.5 to 1 micron.
And the diameter of an atom is not easy to calculate, either, because there is no easily defined outer boundary of an atom.
But if you say a really sharp apex is 0.5 microns wide, you can get an idea. 0.5 microns is 500 nm. An atom of iron is about 140 picometers, or 0.14 nanometers in diameter. So you could have 3,571 iron atoms side by side across the entire apex of a sharp edge that is half a micron wide.
Probably better to use microns as a unit of measure, as atoms aren't a single uniform size and, since we're dealing with molecules, aren't real helpful anyway. Even then, I suspect it would be really difficult to accurately measure.
Steel, I would presume, though I suppose it could be a different blade material.Molecules of what?
Only for veterinary use, however.Atoms and molecules are extremely small in relation to the much coarser crystalline structure of steels. The granularity of the crystals will limit apex radius long before you get down to atomic scale. Now if you want really sharp edges, glass is the way to go because it lacks the crystalline structure found in metals. Obsidian (a naturally occurring glass) is used for tiny neurosurgery scalpels for this reason.
