Gary W. Graley
“Imagination is more important than knowledge"
- Mar 2, 1999
Knots have fascinated me lately, I've made a lot of lanyards that use Diamond knots, Wide Diamond knots and snake knots as well as a whipping knot to keep the lanyard in place.
But recently learned of a knot called a Reever Bend. This is the type of knot used to tie two ends of cordage together, either to end up with a loop or just to extend a length of cord. I've used it to make a loop to hang a bird feeder so it can be hung on a hook, using that knot made it much neater and also very strong.
Other knots I am familiar with such as the bowline, square, sheets bend, half hitch, clove hitch and the like, but I hadn't heard of this Reever Bend and quite like it's look and strength. Also you can untie it fairly easily but while tied, it's quite strong.
Here's one that I tied recently, I usually will tie it again every few days to make sure that I have the method down pat, otherwise it'll 'slip' away from me so practice practice practice
Untitled by GaryWGraley, on Flickr
This is the video that I learned the knot from, he does a very good job of explaining, even for me...
So, I encourage you guys and gals to learn this one if you haven't already, it will be a good one to have in your library of knots
G2
G2
