The Kospet Hope smartwatch features AMOLED display of 1.39 inches with 400 x 400 pixels resolution to give you crystal clear image viewing experience. You have an option to change the pre-installed watch faces or even create your own watch face. On the right side of the panel, you will find a couple of control buttons. The camera is placed on the front panel while the back panel features a heart rate sensor along with the charging connector and SIM card slots.
Product Features:
● Ceramic Bezel
Die-cast forming, 1600℃ sintering and advanced dyeing tech not only cast the jade-like luster on it, but also made it as tough as metal.
● 1.39 inch AMOLED display
Wider visual angle, higher contrast and lower power dissipation.
● Dual 4G-LTE, Global Frequency Bands
Supports dual 4G-LTE, like TDD LTE and FDD LTE, 5 types of network and 23 kinds of frequency bands including WCDMA, TD-SCDMA, GSM, etc, covering most of the countries and regions in the world.
● The First 3GB + 32GB Smartwatch in The World
Powered by MTK6739 quad-core prossessor comprised of 4×A53 cores with 1.25GHz dominant frequency, comes with 3GB RAM and 32GB ROM, packed Android 7.1.1 system, you can download more applications through Google Play Store.
● 8.0MP Camera
Record every beautiful moment at your wrist.
● 9 Kinds of Professional Sports Modes
Including running, football, badminton, etc. Start the sports modes, and your exercise data like time, distance, heat will be recorded and saved for your next check.
● Heart Rate Monitor
A new PPG heart rate sensor using PixArt technology was built in, increasing the monitor accuracy by more than 60% while largely reducing the power dissipation.
● GPS + GLONASS Dual Positioning System
Larger signal cover, able to detect the location and outdoor sports trail with more accuracy.
● Detachable Strap
The original strap was made by pure silicone, breathable, comfortable and durable.
● IP67 Rating Waterproof
Can be flushed or briefly soaked.
● Raise Hand to Wake Up The Screen
When you want to check your watch, raise your hand to wake up the screen for the latest information.
● Custom Dials
Not only possesses dozens of officially designed dials, classical dials and massive ones online for downloading, also supports custom dials.
● Smartwatch APP Wiiwatch2
Can be bound to synchronize data, check daily sports info and set up the exercise goal and modes through simple scanning in the APP.
The Kospet Hope is a piece of art, the combination of metal and ceramics endowed the watch a sort of bussiness style, CNC engraved body is filled with sense of technolological line: https://gearvita.com/kospet-hope-4g-smartwatch-phone.html
Related products:
huami amazfit verge smartwatch
xiaomi huami amazfit bip smartwatch
Product Features:
● Ceramic Bezel
● 8.0MP Camera
● Detachable Strap
● Custom Dials
Related products:
