While I really like the nice wide belt loop and the firm grip that the Kydex sheath keeps on the Steel Heart, there's one nit I'd pick.
The folded-over belt loop on my SH sheath is fastened with only two of the rivets (which may prove to be enough strength-wise), then extends to within about 1/4" of the next two rivets. This leaves a squared off flap of Kydex that can catch on a pant leg as I walk.
Had the flap been made a tiny bit longer & attached to the second pair of rivets, it would not only have handily fastened down the end of this flap, but would have also provided the extra security of doubling the number of rivets holding the bottom of the belt loop closed.
I figure I'll drill a couple of holes spaced to catch that flap end, rivet & epoxy it to the back of the sheath, and probably radius the corners of the flap as well, to minimize snagging potential. I'll do it when I get the spare time.
Still, IMHO it would have been better to do at manufacture time since machines give a more consistent connection.
Have others seen this configuration on your sheaths and, if so, in the long run did it hold up okay for you?
Many TIA.
When a woman speaks, listen.
When she is silent, listen twice.
