- Jul 25, 2007
Prior to laser engraving, the steel will survive any destructive test I can think of (e.g. https://www.instagram.com/p/CIRg4H-jXbs/).
After engraving, one lazy hammer blow will snap the knives in two. The engraving is approx 0.003" deep, and a simple engraved 3/8"-long line is enough to create the weakness. The engraved area is warm to the touch. Again, to be clear, prior to laser engraving, I can pound away on these knives with a hammer.
Steel was purchased from the mill, HT'd at Peters (tempered at 400F). A post-engraving 400F temper will not fix the problem. Tempering to 700F does fix the problem at the expense of 8-ish hardness points (I'm assuming there's a TME loss of toughness in the 500-650F tempering range).
Obviously engraving is adding a stress riser, but I'm astounded by the difference in apparent toughness between the pre and post-engraved knives.
Some questions I have for the experts:
- Toughness is the energy absorbed when the steel is broken, which is distinct from the force/energy required to break the steel. Is the former (energy absorbed when broken) directly translatable to the latter (force required to break)? Obviously my crude hammer test is measuring the apparent force required to break the knife; I am not necessarily measuring nor concerned with energy absorbed.
- On one hand, we have the well-established concept of TME, and plenty of hardness/tempering graphs that show a toughness peak around 400F, a toughness dip in the TME zone, and increasing toughness above the TME zone. On the other hand, we have the notion of "bluebacking" (drawing down the hardness of the spine), we have blue springs, and in my testing on the engraved knives, an apparent increase in toughness at "blue" tempers (e.g. 500, 550F). How do we reconcile these two? Why are springs tempered to 40s or 50s if optimal toughness is closer to 60RC for many steels? Why do saw manufacturers heat-treat 8670 to 52RC?
