- Sep 20, 2015
I've been researching.
The quote below tends to go best with my intellectual (but no experience) take on honing oil.
I fooled around with Buck Oil when I got my first set of disastrously bad natural Ark stones when I was a kid. The experience sucked so bad. Coarse stone not coarse enough to actually sharpen a dull knife and the surface was so flawed and made of different textures I may as well have been using a rock out of the drive way.
Fast forward to a decade ago; I bought a super nice Dans 10 inch translucent and just used water. I have never tried oil on it. I never use it because most all my alloys from A2 to you name it (S110V etc.) are just not fun on this stone. I just like the stone so I bought one and that't why I have it . . . OKAAAaaaayyyy ????
So what is 'bagger wittering on about ? ? ? ?
I have been looking for a pocket (manpurse) stone to use at work exclusively to touch up my box knife and Case CV knives on the spot when they get a little tiny bit less than sharp. I have been using a DMT Ultra Fine 8,000 but don't like how the pointy tip of the box knife gets into the dimples . . . I've fooled around with a 4,000 Shapton Glass stone from my Edge Pro Apex held free hand but that isn't quite what I am looking for; I want to go edge leading and the stone gets a tiny bit gouged from my less than perfect technique free handing it.
So . . . that brings us to the stone I have in my hand as I type this ( I have three arms ) . . . a Dan's Black Hard Ark pocket stone. It is dry. I have not tried it yet. It will be going to work with me tomorrow for a partial day (off early YEAAAAAAHHHHHH).
I have seen people here recommend as much as using Vaseline (high viscosity lube) to as fine as just Kerosene in the woodworking forums and mixes of proprietary honing oil or thin mineral oil with Kerosene or paint thinner added to those.
My first impulse is to just use water. I'm a big water stone user. The cutting oil thing spoken of below also makes a lot of sense to me though.
Every one grab their dead horse beating implement of choice.
Flails up !
and commence !
Here is the link to where I got the quote below rather than fire up that thread again :
https://www.bladeforums.com/threads/does-anyone-use-arkansas-stones-without-oil.303983/
Flails up !
and commence !
It isn't necessarily true that honing oil produces a significant lubricating effect that slows down sharpening. The reason you use oil -- or kerosene, water, or whatever else -- is to a) prevent metal "swarf" from clogging the stone, and b) to reduce the amount of wear on the stone itself.
If you use too heavy or viscous an oil on a stone, then certainly abrasive action can be reduced. But heavy oils aren't really necessary. Kerosene works very well for fine India stones, and mixing a small amount of mineral oil with kerosene works well for soft Arkansas (or so I'm told; I haven't used Arkansas stones for many years.) The net effect of using a proper honing fluid -- a better term than oil, IMO -- is that your stone doesn't tend to load up, and so keeps cutting more efficiently over time, plus you can use more pressure than you could dry without producing so much wear or clogging of the stone.
Of course, if you have a stone that doesn't tend to clog with swarf when used dry, or washes out OK, then that reason for using honing fluid doesn't matter. But your stone may still be wearing much more quickly if you use it dry, and if it's a quality translucent or hard Arkansas stone, there can be a bit of an investment at stake.
Finally, here's something to try if you have any doubts: cut four pieces of steel from some unfinished stock. Take four pieces of wet-dry abrasive paper, 200-600 grit, depending upon how rough the steel is you'll be working. Leave one piece of paper dry, the second one wetted with water, the third with kerosene, and the fourth with a good, commercial cutting/tapping fluid such as Cool Tool II. You'll notice some big differences in how fast the different sheets cut, the uniformity of finish they produce, and how long they last. And you'll find that lubrication isn't the real story behind using honing fluid.
Dave
