Eric Isaacson
Pirate
- Dec 19, 1999
I have read at least 2 posts on the forums recently that have questioned how the coating looks on the CG Busses. I am referring to the wrinkle or crinkle coat that is currently being used on the regular production pieces. Some consider it ugly, if this is true why is Busse Combat using it?
I'll tell you why. It has always been Busse Combats motto that The Beauty is in the Performance. If it works use it. Does it work? Yes, it is incredibly wear resistant. The crinkle coat is used because it has been determined through extensive use it is the best coating available. For those not familar with the coating see the attached pic. It appears that it would easily come off since it has those raised areas of coating, however, it is just the opposite. The raised areas will take the initial wear, they will begin to smooth out and after much use that part of the blade will still have the black finish only smoothed out. The life of this rough finish is extended when you compare it to smooth finishes of the same thickness. Only after the finish has smoothed considerably do you begin to see any of the coating wearing off.
Now regarding the Aesthetics of the Busse Knives.. you might think, they can't perform well because they look to good. A lot of the Busse Blades look good, especially some of the current variants and customs, they look awesome, cool, mean, (I need to find the thesaurus for more adjectives). So you might ask... If they look good does that mean that on these, aesthetics were more important? The short answer is "NO" You must remember that beauty is in the Performance, so the most important objective is that every thing on the knife is there to increase performance, that is primary. The aesthetics are secondary, if a Busse looks great you can believe it will also perform great.
Do I think Busses are unattractive? No, Because for me, my enjoyment comes from use, if I want something just to look at I'll buy a picture. If I want something to be an incredible useful tool, I'll buy a Busse.
