- Nov 2, 2010
Drill spirals on the floor can get embedded in the sole of your boot. Anything your boot walks on can get damaged quickly. My hardwood floors bear a few scars.
Wherever you do work, practice dropping something. See how much damage it takes, and where it rolls off to. Take countermeasures. Rubber horse stall mats are great for me.
If you have a gap between your work rest and your belt, this creates a pinch point. Your work piece may get pulled into the gap. Your fingers may follow. This happens more easily if a flat platen is set at an angle. I now use a flat piece of steel clamped to the work rest as a "bridge" over the gap to protect the survivors of the fingernail assault.
Tacking on to the "don't work tired" - fatigue creeps up on you. The smaller muscles that you rely on for balance, fine motor skills, etc may not feel "exhausted" but they may be less than 100%. These can cause errors. If you work a needle file on a guard, you may be unable to keep the intended angle. A sore neck might distract you while grinding.
