Well,it all worked out pretty much as planned.
https://imgur.com/a/N4BXyZi
No major mishaps,barring a mistake in calculations due to which the dogs are 2"-3" longer than specified.
The donor for steel bits was an old Nicholson 10" mill bastard.
Here it is wired for welding,teeth,dirt,rust,and all,flux should take care of it.
The sloppy fit is good,as it'll allow the flux to get in there,after the initial low heat.
https://imgur.com/9BRuYSm
After the initial weld-setting heat,wire can be stripped off...
https://imgur.com/a/PCqx7uZ
And couple-three weding heats later the bit is on.I won't worry about trying to blend it in,i can feel with the hammer that it's solid,and won't worry about pretty:
https://imgur.com/vYWPlGm
And so on,all around the other three points.That file(whatever it is,W1-1095-something,anyway)feels wonderfully stiff under the hammer,and will serve,methinks.
Edit:I screwed up the photos,apologies,and i think i got them straight.
