Cliff Stamp
BANNED
- Oct 5, 1998
LSkylizard said:In the wilderness, yes, you have no choice.
Yes you do have a choice, in preperation, consider what people used to take and how they used to treat patients and how they do now. How much more equipment does a paramedic have on hand with him now compared to the same job just a few generations ago. They "made due" back then as well, but generally you can save people now that you could not back then.
Clearly, if you think the chance of having a less then ideally suited axe that takes three hours to cut a tree will be such a liability, take none, the same for maybe a long knife etc...
Yes it is a liability if the axe is unsuited to the wood, it tends to glance much more readily, the much lower efficiency raises fatigue and chance for injury.
Assuming a complicated operation say... heart bypass? brain aneurysm? I again say there is no parallel.
It was in regards to the nature of the question not the details.
You can get utility in the wilderness with the two base items alone.
An axe geared for woods is of little value when there are none, and an axe geared for a significantly different wood type is nothing but a dangerous liability.
I apologize if somehow you believe your survival ability has been insulted by my "silly" scenario.
You seem to be personally insulted because of the above label, I asked silly questions all the time when I first talked to Joe about knives, same with Jeff and even more with Alvin, and most of my questions to Chas are still pretty silly. But you learn and hopefully get to the point where you can ask sensible questions and eventually ask them a question they don't know but think is a reasonable one. I think it took my like six years or so with Alvin. It was at least a few years with Jeff and those guys still correct me on a fairly regular basis.
Let me not belittle how dire the consequences will be if you take too long to cut your log.
Consider building a shelter in 5-10 minutes vs hours, in adverse conditions, this assumes you are properly prepared with the right clothing for that enviorment for that seasons (which isn't all the same gear all across canada regardless of the time of year) otherwise you won't last that long anyway. Consider the axe breaking on the tree in the first chop, consider the axe glancing badly on the first chop and going wild and hitting at best the ground or at worse you.
-Cliff
