I have used many types of steel for other purposes besides knives. The M series is just not a fav of mine for knife blades. I dont see the advantage to this series of steel in blades.. In the applications I have use these materials they were used for hi shock NEGATIVE, NETURAL,SLIGHT POSITIVE rake cutting with backing..
Drills, Gear Hobs ect. IF your thinking your going to get increased life on the edge there are better choices IMHO.. Cpm420v,v10, v15,440v, 52100, ect.. The problem I see is that the m series was designed to have backing or a lot of material behind it for shock.. Knife edges are not backed well . They are thin. I would look for a material that will take the shock of bending and not chip out. If you take m2 or 4 or rex materials to a thin edge at 62 rc. you are asking for a chipped blade. Im gonna get blasted for this one I can feel it comming.
But we all have or own ideas about whats right and whats wrong. I just want to know what you see as the advanage? I have made MANY industrial thin blades. A2 is the steel of choice .. Try this take a hss drill bit grind it down in the middle to a thin section keeping it cool as you do . Put it in a vice with the thin part sticking out just a little .
TAP IT WITH A HAMMER. IT WILL BREAK IN A HEART BEAT.
Take the edge of a knife heat treated properly in a more common knife steel to about 58 rc. do the same . It will flex before it breaks.. The m2 or 4 or rex will
hold an edge for a long time .. but cpm420v or 440v and others will also . The alloys in it are tough. So 58rc a bit of spring and good edge holding or 62rc good edge holding and brittle?
There is also the heat treating concerns with the m series.
Thats your choice. 52100 is a great steel for this application also a2, 440v 420v if you want tough and spring.. Just my 2 cents worth..
