Related item is, even though we agree as above, that the foundational and most important work is all on your stones--especially the coarse stones--there are also a number of folks who've been doing for a while what I did here, basically adding an abrasive in the 3 to 6 micron range as a value-add refinement step with super steels. So even though the beginning process of your sharpening is the most important, how you finish can make a difference too. Last time I talked to
@bluntcut, he was using a diamond plate in this 3K to 4K range. Pretty sure
@Jason B. uses a UF ceramic which would fall in this range, both to refine and maintain edges.
HeavyHanded
has his own
compound in that range (4K JIS), which when used to strop on the Washboard system, accomplishes the same goal.
The common theme is that regardless of how folks use this in their sharpening process, some are finding that adding an abrasive in this medium-high grit micron range as a refinement step can add some value with these steels. This was my first time trying this approach with Elmax, and first time using this new 4 micron CBN from Bark River, but it definitely made a difference. No vested interested in saying that, not selling anything, don't work for Bark River, and personally, if I have any sharpening bias at all it's striving for greater simplicity and reduced steps. But it was super clear in this case, adding a 4 micron abrasive helped. I'm not sure that stropping was what made the difference, more likely it was just the abrasive--the size, and the fact it is CBN. I assume if I had used a 4k diamond plate to refine, I could've gotten similar results.
Based on what these others guys are doing, and what I saw in this test, I'm going to keep experimenting with this idea of using something 3 to 6 micron to refine/maintain super steels. With my variety of blades in S30/S35, M390, 20Cv, Elmax, and a few others, the maintenance routine could be something like: DMT F or EF, followed by strop on this 4 micron CBN, OR by work on another abrasive in this same micron range. I'll keep trying this Bark River 4 micron for a while. Another option could be HH's 4K compound, which is cost-effective and has a mix of diamonds + SiC. Could be the DMT 'medium'
6 micron plate they've come out with recently in this range, that way would give the benefit of an 'all stone' solution without stropping.
