Sorry Darrel, I was in texas and couldnt answer questions the way I usually do..
Everybody else has summed up you question pretty good, I would just like to add one thing.
Be carefull of micartas, especially paper based, always make sure you cut you peices in the same linear dirrection on the sheet, a lot of the new micartas out are made of linear paper(sheets) intead of the paper pulp varieties, so you will get a definite grain like pattern running through it instead of it being a solid color.
As far as the finishing is concerned, use fresh abrasives, and hand finish to a point beyond where you think you should stop.
This will make sure you dont overheat and burn the micartas, which changes the color and texture of them, and will give you a good even finish. Black micartas turn green, and red micartas turn yellow, if sanded too hot or if you try to take scratches out with the buffer.
Hope i could help, even if I'm late..
Alan.
