Those are awesome. How thick did you cut your Micarta stock?
What bits did you use on the holes? Brad point?
Thanks! I was really pleased with how the scales came out. For the micarta, I ordered 1/8" brown canvas micarta from an online billiard supply store.
For the counterbore holes, I built my own counterbore bits (used generally the same method described by the guy in the Youtube video embedded below, except that I used a Dremel cutoff wheel to modify the bits instead of a grinding stone). The counterbore bit sizes I used were 3/16" for the scale attachment screws and 5/16" for the pivot screws.
For the through-holes, I used a 1/8" bit for the scale screws and clip screws, and a 3/16" bit for the pivot (I think...don't remember for sure on the pivot). Also, keep in mind that the pivot barrel and backspacer barrels protrude through the liners just a tad, so you will need to drill or mill out a tiny little bit of room for these on the inside of the scales to get the scales to sit flush against the liners when assembled. Additionally, the scale that goes up against the lock bar has a small milled-out area for lockbar travel during opening/closing. I used used my Dremel 565/566 cutting adapter with a tungsten carbide cutting/engraving bit to manually mill out this section by setting the depth of cutting to something like a couple of hundredths of an inch.
The process went something like this: 1) trace an outline of each scale on the micarta sheet; 2) draw the milled-out section for lockbar travel and mill out that area as described above; 3) cut the micarta roughly to size using the outlines in #1 as a guide (I used a couple of Dremel cutting attachments for this, but I understand a band saw with wood cutting blade would have worked a lot easier); 4) use the holes in the existing scales as templates to drill out the various holes (small holes first; counterbores second); 5) once all holes were drilled and I confirmed everything fit together properly, I used a 60-grit Dremel sanding band with my Dremel Rotary Tool Sanding/Grinding Guide Attachment to sand the micarta piece flush with the steel liners, which I had attached to the micarta with the knife's hardware (that way, you know you'll end up with a perfect fit); 6) I sanded down the 90-degree edges on the micarta scales to round them off, then flat-sanded the flat sides of the scales to remove the outer polymer layer and get down into the fabric, starting with 60-grit and working down to 120-grit for both (I wanted a grippy final texture); 7) Then I spread on a couple of applications of boiled linseed oil to the finished scales to bring out the rich brown color again. The guy in the 2nd embedded video below (not my video) shows some of the process I used.
The main tools I used were a drill press and a Dremel. Hope this helps!
<iframe width="560" height="315" src="
" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
