- Nov 27, 2013
How much do you guys think the surface grinder weighs?
If you're willing to rent a truck and trailer, save yourself some grief and call a tow company to see what they would charge you to rig and set the machine for you. They will be able to do it with their smallest truck, and will do it in the way you proposed using a cherry picker, sling it under the boom, lift, drive trailer out from under it, back it into your shop and set on your concrete/pipes/rollers/etc. He only charged me $85 to do it. It took 30 minutes including unstrapping and BSing. Well worth the money. Hell, if the machine is local see what it would cost to pick it up where it's located and drop it at your shop, and maybe you can kill 2 birds without much more total spend than renting a truck and trailer.
For your phase question on the grinder, yes and no. If that's an automatic machine you have two motors to spin, the spindle motor and the feed motor. In many cases that feed motor is hydraulic. I think in the case of a No2 it's a flat belt setup. Either way it's generally not recommended to run multiple motors off a single VFD concurrently. So yes "all you would need...is a VFD" but, to operate the spindle AND the feed motor, you'd want 2 VFDs. Or a single phase convertor.
Thanks for the advice.
I ended up getting this:
https://www.ebay.com/itm/SHARS-Dial...833710?hash=item46206ea86e:g:gZYAAOSwB09YIOuz
And this:
https://www.ebay.com/itm/SHARS-030-...360605?hash=item51ba90281d:g:Lb0AAOSw28pZwYLQ
Hopefully these will work to tram my table and index holes...
