Miners axe, rafting axe, construction axe
The Plumb is 26" and the Mann is 24.5"
Miner.rafting by Agent Hierarchy, on Flickr
I actually use and quite enjoy a 30" Collins (marked opposite side) with a handle set up just like the Plumb in the picture. I find it does a great job splitting if your rounds are setting on another round/block.
300Six, I bet you are right that the shorter handles are something suited to tighter quarters, choking up, and being persuasive lol.
The handle on that Plumb is super nice! Must have been customized.
S Square_peg if you don't mind me asking. What was OAL of the plumb 5lb that you have that never was hung? Trying to find out length of a true full bit.
You can reset the lines by working in from the edges with either a knife (shaped) file or a slender half round file. Then once you have a track to follow use a 3-square (triangle) file. The 3-square file has the correct angle for the waffle pattern.
May I ask what file you used to stand your waffle pattern back up,jewelers?
I found the thread where I described my process.
Thank you!
