Price is $300 ea (shipped within CONUS). If you live outside the US, I will contact you after your order for extra shipping charges.
So basically what this thread is saying is that I need a Shapton glass stone.
Because that's the conclusion I'm drawing.
"I can tell a huge difference"
I think you were saying the 5000 makes it cut better . . . is that what you meant ?
The leather needs to be boiled, or better yet hot waxed. Then it gives quite a bit more protection, but won't make the most comfortable apron.
No direct experience here, but I've heard that actually does little to increase the protective qualities.
Here's a post from Ankerson from 2010 where he talked about the polished vs. non-polished edge for cutting results and the polished edge did better then as well:
Ankerson's Polished vs. Non-Polished Edge Cutting Results Thread
Here's the quote from the post that I like:
"The sharpness of the edges will equal out within the 1st 30 cuts when the edges stabilize then towards the end the real differences really start to show up between the polished and non polished edges because it takes a lot longer for the polished edge to break down."
I may be wrong, but after he found the Congress Tools Moldmaster #400 stone, he concluded that a clean coarse edge works longer than a polished edge in his rope slicing tests.
Miso
