Mora bushcraft black sharpening?
Hi I'm new to knife sharpening and I recently bought a Mora bushcraft black. I noticed it has a small micro bevel on the scandi grind. What does this mean as far as sharpening? Do I sharpen this knife like how I sharpen my Mora classic 1 which is pretty much lay the bevel flat on the stone? Or should I sharpen it differently? Thanks. Your advice will be appreciated.
I can't speak for everyone, but I ended up using my Spyderco Sharpmaker on my Mora with great results. I liked the Scandi grind,, but didn't want to break out and set up the water stones every time.
To each their own!
Basically either way is fine. Lay it flat and re-establish a zero grind like on your classic, or do a microbevel like rcb2000 (and me!).
Microbevel ends up being a bit stronger edge. As long as you keep the ANGLE the same you should be fine. Just don't forget to lay it flat on the scandi grind every once in a while.
