- Jan 30, 2010
Lol, I wouldn't be too sure about that one.I'm sure no one has thrown their knife against a brick wall 500 times
Price is $300 ea (shipped within CONUS). If you live outside the US, I will contact you after your order for extra shipping charges.
OP mentioned snow, water and mud. Gloves or wet hands make some locks much harder to operate even if they may be the best lock up.
a little bit of saltwater will hurt the most expensive folders.
I'm sure no one has thrown their knife against a brick wall 500 times, but my question relates to extreme abuse and durability. I know that the title is ambiguous, so I thought I'd lay out some criteria below:
1. Scales or frame must be made of a very hardy material resistant to warping and breaking.
2. Opening method would most likely be bare bones manual, I assume. No springs to break or bearings to get dirty.
3. Locking method needs to withstand as much force as possible.
4. Blade material, for this concept, could forgo sharpening and overall sharpness qualities in exchange for edge retention, scratch resistance and corrosion resistance. In other words it doesn't have to be super sharp, and sharpening can be a bitch, but it just needs to maintain itself. Thick material.
5. Blade shape should be short, snubbed and fat enough to avoid chipping or breaking. Length and point are not necessary for this build.
6. Any screws or bolts holding it together would need to be high-quality. The less pieces to break the better, so one-piece construction would obviously be better for the knife overall.
I'm sure I left out some crucial components of a durable knife, but that should get the ball rolling.
So are there any knives that meet this criteria? What in your opinion holds the title of most indestructible folder? What materials are considered the most durable for blade and handle?
The Opinel #10 Inox is the toughest folder I've used because of just these concerns.
It's among the few folders that you can bury in wet sand, dig it out, knock off the loose stuff and then use with confidence. Generally speaking, simpler is better when it comes to durability.
NOTE: I don't consider lock strength to be a real criteria for a folder. The Opinel's lock won't prevent it from closing if you lean on it.
My Kershaw Cryo has been through a lot and still in great condition. I would suggest it to anyone.
I own a 7.5" pry bar that is very small and relatively light. I paid $4 for it, and if you give me enough time I'm pretty sure I could tear down an entire house with it. It seems to be indestructible, at one point I stood on the handle to trying to get a particularly stubborn nail out of concrete, and I was sure I was going to trash my high quality $4 tool, but in the end I launched that nail into the stratosphere and my $4 pry bar seemed none the worse for wear.
Why anyone would want an overbuilt pocket brick of a folder that would easily be outperformed by a SAK and my $4 pry bar is beyond me.
I'm not near it today or I'd take a picture for you. This is what it looked like new:
If you need a really, really strong knife, you are almost certainly using your knife wrong . . .
You should write a book.....Battoning with a Prybar.
I'm not sure a book would go over well with anyone brilliant enough to choose a folding knife as the best tool to baton wood with; I mean, do people who can't read buy a lot of books?
