- Aug 31, 2011
Maybe some of you have heard of this stuff. I don't think I have ever seen it on a knife for sale by custom maker. It is a G10, in a standard thickness, that comes with a smooth, clear peel-off layer, which covers a grippy, woven-like texture beneath. The idea is you glue it up onto your tang, then remove that clear protective layer, to expose the textured surface.
I ordered two sets of scales from USA Knifemaker. When It arrived, I could not figure out how to peel off the clear protective layer. I sent an email to them, and they replied promptly, saying I just needed to get it started with a knife. Not wanting to scratch up or dull a nice knife, I got a cheap steak knife, and started one corner. After carefully loosening about 1/2", I was able to grip it hard between thumb and forefinger, and finish peeling it off. It takes a firm grip, even after you get a corner started, in order to peel it.
I believe the scales I ordered have a thickness of 3/16" - perfect for the small fixed blade I made. I glued them up, ground off the excess, then further secured them onto the tang with peened pins. The result does not look as good as I had hoped. The processes of glueing, sanding, shaping, and then putting an edge on the blade involved a lot of handling. Consequently, there were greasy smudges on my finished product. I tried scrubbing with acetone, then isopropyl alcohol, then just soap and water. Still could not get the stains off. I may have to just sand off the texture in order to remove the stains. The handle will still look pretty good, but it won't have that same grippy texture.
If I choose to use this material again, I will wait until after glueing, shaping, sanding, and sharpening, before peeling off that protective layer. That should leave a nice, clean, surface on the handle. My mistake this time was to remove the clear protective layer before doing all that other work.
This material looks promising for smaller knives. I like a smaller knife to have flat scales, and grippiness.
Your thoughts are welcome. I will be able to post up pictures early next week. If you have any pictures of knives with this material, please post.
Thank you.
Andy
Thank you.
Andy
