My first Damascus blade
Jason Fry
Over the years I've used other folks' Damascus steel quite a few times. This blade is the first one from my own Damascus. This is 21 layers of Aldo's original 1084 and some 15n20. The guard is wrought iron wagon rim that belonged to my great great grandfather, George Kromer. The handle is curly maple. Overall length is around 12 inches. It was built with a threaded rod through the handle, fastened with a corby head that was then covered with a Texas mosaic pin. I'll have it on my table for the Silver Spur show in Abilene Feb 24/25. Although this is a regular "gun show", we've worked with Kim the promoter and will have around 10 knifemakers from the Texas Knifemakers' Guild there, as well as Terry Dunn with three tables of stabilized wood handle material of the highest grade. We'll also have educational seminars at 1:00 both days.
Nice work, Jason. Are you forge welding by hand?
I stuck one billet by hand, then decided that was for the birds. I called a buddy who has an Anyang 25kg and an Uncle Al press.
That said, I'm in the process of building a dedicated welding forge, and have located the materials (free!) for a helve hammer. Should be hot and heavy by summer time.
Are you sure that you need a dedicated welding forge? What kind do you have now?
I don't have to have a dedicated welding forge. I've got a 15" horizontal with about a 5" round opening, running a 3/4" mikey burner. I'm working on a vertical with a blown burner, because I want one. My current forge stuck the welds I did in this batch, running 12-15 PSI.
Great looking knife Jason. I love the use of the old wagon wheel from your great great grandfather.
