Codger_64
Moderator
- Oct 8, 2004
For a month, It had been sitting on a shelf in a display cabinet beside a well used brother. During that time, I noticed the contrast between the scratched bolsters and shield, the hand rubbed staglon scales, and broken blade of the knife from last year's construction season and the showroom gleem of it's replacement. Today, I took it down for the first time. A few strokes of the hone on each blade and into the work pants pocket it went.
Now, at this point some may gasp that I would take an Uncle Henry stockman, fresh from the factory wrapping and sharpen it for every day carry. I bought this knife to use as a tool, and two more after the Schrade closing. I will likely buy four or five more to put back for the same reason. To use in my construction business. Look at it this way: America is still working with Schrades. And every one I deflower makes the remaining shelf queens more rare. I'm doing you a favor!
Maybe some day I will do a review of this knife, but it would be pointless. The 897UH is made the way we expect Schrades to be made. I could not tell you anything new about them. Fit, finish, walk, talk, design, etc. are just as you would expect from an American made stockman that retailed for $39.45 in 2004. ($13.25 in 1975!)
After using it to open my morning snack, it scraped PVC pipe of mud and burrs, chamfered newly cut pipe being prepped for building a pool pump intake manifold. It cut string and boxes. It opened a new tube of silicone sealer and cut strips of duct tape. Tomorrow it will reduce a sixteen foot by thirtytwo foot by eight foot deep .20 mil pool vinyl liner into four foot squares to be hauled to the dump, then cut the nylon bands to open the box containing the new pool liner, and slice the invoice packet open. It will cut out the liner hole inside the new main drain faceplate, Skimmers and returns, then a delicate fourteen foot cut around the peremiter of the stair opening.
It will cut new gaskets from sheets of gasket material, cut built up glue from the top of my PVC glue can, then sharpen my pencil and cut the nylon string as I prepare to set forms for repouring the concrete deck. It will open bags of sackrete for the fence post replacement, and four fifty pound bags of sand filter media, slice off sticks of two-part pool repair epoxy, cut a new pool safety nylon rope to length, chop caustic chlorine tablets, open bags of calcium hypochlorite, puncture jugs of algaecide, and on the way home open cans of brake and power steering fluid, and at the end of the day, clean my nails. And more.
During the day it will NOT be loaned, used as a hammer, chisel, screwdriver, punch, prybar, or projectile. Loaning to a worker is what caused the broken blade on it's brother late last year.
The same knife will do these things and more for a couple of years or more if it does not get lost, appropriated, or dropped into a load of fresh concrete.
I like my 897UH's! Wonder if I can get a deal on them by the dozen? Nah, I want to retire some day. If I had that many more I would never live long enough to wear them all out!
Codger
Codger
