- Feb 15, 2018
Not to much progress but finally got to playing with the titanium sheet I bought. It is .156 and I got it from alphaknifesupply, I unfortunately can't get this surface ground as the company I contacted locally will not doe it since it is non magnetic. (I really hope to get a surface grinder one day if I ever get to make more of these!) Hoping the knifemakergrade titanium from them is flat enough to work, gonna hit it on the granite plate and hand sand it a bit to verify. Anyways this is all new to me so everything I do moving forward is a guess. The plan is two cut out two rectangles that will fit the handles and will super glue them together. that way all the holes and profiles will line up perfectly. My only concern is the titanium heating up from grinding and having the pieces split app art. I'm going to have the paper template glues on so I don't want to get it wet at all. I'll see how this goes. If I screw up these two pieces, I will be ordering some similar thickness aluminum and practicing the process, other than the lock bar of course.
20 seconds into cutting the titanium on the band saw and the blade brakes.. Lesson learned, always use new and sharp blades/endmills/drills/
New blade cut like butter! Also got to get a rough idea of the total thickness of the blade.
And just for fun, here is the evolution of learning! Bottom piece was my first try, notice how I used sv35vn, very big mistake or should I say expensive. I did not have my DRO at the time and used a optical center punch, that I later found out was faulty, punching off center. pivot hole and stop pin track where very far off, no good. 2nd and 3rd try, is learning that when your using cheap canadian tire (harbor freight) drill bits, your life gets very difficult, at least when they are dull. 3rd try is my first successful blade done on 01 tool steel. I even decided to grind a bevel to get an idea of how things will look. I got impatient and burned the tip. and the last blade, very top is my first successful blade done in the actual steel and thickness. Now I just got to figure out do I bevel before or after heat treat?
Thanks for all of your input and comments so far! Gives me extra motivation to keep on going with this! Feel free to offer any criticism or feedback, This will be my second knife and if I can pull it off, I plan on making plenty more! It's very fun! If anyone has any suggestions or questions feel free to chime in. Thanks guys! I'll make sure my next post has a good amount of progress done!
