db:
mmmm, na, I have a number of blades that will go through in two strokes, one if I'm careful about technique, against a board. You could just put a loop in it though, stick the knife edge up in the loop and pull. A good knife should go through in one pull, no problem. A good efficient edge will do this.
Will:
When I detroyed Walt's Talonite knife, I set out to cut straight through the bottom of the bottle, diametrically. I am usually not successful. The blade usually gets stopped at the center where the plastic gets thick and hard, but the edge failed before I got that far. If a person cut towards the center of the bottom until they just about couldn' cut anymore and veered off to cut around in a circle, that would put a lot of lateral stress on the edge. If it survived, that would be an indicator of good edge strength.
