Buck 119; KaBar "Marine (and Army) Fighting Knife"; Ontario 499 "Jet Pilot Survival Knife" and 498 "Marine Fighting Knife" (identical to the KaBar, but is still Mil Spec, and is the current issue) Mora with beech wood handle/grip (Number 1; Number 2; etc) all have three things in common:
1) They are not known for breaking.
2) They are known to be good for "heavy" use.
3) They all have a stick/rat tail tang.
(Some would call it a "full tang" since it is the length of the handle/grip; you just can't see it.)
Just because you can't see the tang down the middle of the handle/grip, don't mean it is a "weaker" design.
The 119 is a fine knife, that has been in continuous production for
over 75 years. The 75th Anniversary was a couple years ago. I believe it is Buck's
second most popular of the 100 series, behind only the 110 in sales.
I strongly suspect that for the 119 to trail only the 110 in sales,
and to be in continuous production for 75 years and counting, Buck must be doing something right.
As
DeSotoSky
mentioned, depending on your location, the 119
may be a wee bit large for EDC. (be sure to check your local laws concerning blade length. Some jurisdictions are still "pre-stone age" and have maximum blade length limits.)
I live in Idaho. No blade limits, but I still got looked at more askance (and more often) than "normal" when I carried my 119 around town and/or to the grocery.
The 118(?) might be a viable option. The 118 (I think I have the model right ...) is pretty much a "mini 119". Same profile, but with a blade of between 4 and 5 inches.
From over 40 years of hunting, I've found a blade of 3.5 to 4.5 or so inches ... 5 inches at the most ... much nimbler and handier than a longer knife for field dressing and peeling game of all sizes.
(generally speaking, shorter blades are also more comfortable when you sit, and don't have the sheath tied to your thigh...)
Of the two you mention, I'd choose the Buck.
1) Better Customer Service (they actually answer emails, the phone, and answer questions, even from a nothing like me
2) Buck's Forever Warranty is at a minimum worlds, if not galaxies better than anyone else's.
If you pass you Buck in to your Great-Great grandson or grand daughter, it is still covered by the warranty. Most other knives are only "original owner and not transferrable", no matter what the time given is, if you take the time to read the warranty.
3) Buck also offers a "SPA" service. You can send in your Buck knife for refurbishing, and for something like $6.95, you'll get it back looking like new.
(also, if you find a Buck knife out in the boonies, sticks, bottom of lake/steam/babbling brook/pond/river/ or even the ocean, it is still under warranty, and still eligible for the SPA service.)
I have a couple Böker "Plus" and one "Magnum". I've tried contacting them, over the last three or four years with no luck.
If they can't be bothered to respond to a simple question like: "The advertising and box/hang package says "440C". The blade etch says "440A". Which is it?"
from someone who bought their product, Why should I think their "warranty"/"guarantee" is worth the paper its written on, or so much as the ink used to print it?
Sorry. I might be a little Biased. The lack of Customer "Support" and Customer "Service" I've experienced from Böker, ensures I will never buy another Böker.
EDIT:
You might want to consider the Buck 113.
Very capable in the field, when hiking, etc., and not "too big" for EDC.
