Its a good data point but not a bible.
You are comparing HSS which is usually A2 vs White steel which is similar to 1095 with a bit more carbon.
You are also forgetting that White steel can be taken to 65 HRc while A2 would be in the 60-62 range. That difference in hardness would make the steels about equal in wear resistance thus making them sharpen at similar speeds. He is also comparing laminated blades vs homogeneous blades and blades of different widths. In reality, its a test with far too many variables.
http://www.toolsfromjapan.com/wordpress/?p=672 said:
Jason,
If that is the case, why didn't the other stones cut them at the same speed? Why was the SPS-II 1k the
only stone to cut them at the same speed?
Additionally, the HSS in that graph is very unlikely to be A2 as A2 was used in the first part of the comparison, pictured above, while the second graph quoted in the above post was for Japanese chisels made using Japanese steels. Furthermore, the massive gulf in cutting speed results on the King Deluxe, which was essentially entirely unable to cut the Japanese HSS while it still worked fine (if slowly) on the A2 also indicate the Japanese HSS used in the comparison to be significantly harder to grind than A2.
Nonetheless, for the sake of completeness I have emailed Stu to check if he knows which HSS is used in that chisel and at what HRc.
Ultimately, the larger points still stand: Firstly, that the SPS-II were significantly faster on all steels than any other stones, with the relative speed advantage over other stones increasing on more wear resistant steels. The SPS-II stones therefore minimize the extra time needed to grind more wear resistant steels compared to any other waterstones.
Again, in my personal usage I have actually sharpened VG-10, 440C (@ ~62 HRc), HAP40 and ZDP-189 knives with similar edge bevel areas in identical numbers of passes on each stone and identical sharpness test results afterwards (e.g. identical push-cutting ability on phonebook paper, tomatoes, hht, etc.). (Of course, it's possible I am doing more passes than strictly necessary on the VG-10 and 440C since I was used to sharpening them on my older, slower stones).
