It is the same composition as 6BH, but the aim hardness is Rockwell C50 after final heat treat - if necessary.
This iteration should help correct the soft Cobalt matrix holding the Tungsten Carbides that can cause an edge roll, as it will be supplied near Rc48 before heat treatment.
6BH would normally be Rc40 minimum in the full-hard condition. There will be a small sacrifice in ductility, knowing mother nature and the boundaries of what is possible.
Corrosion resistance and non-magnetic properties will be similar to better than 6BH.
The material is not available on the market yet, just looking to gather some real world feedback - hopefully from a maker that is familiar with STELLITE 6, 6K and or 6BH. This product will be made solely in the USA.
I am offering to make and supply two pieces of sheet waterjet cut to shape, one for the test that you can test / keep, and one that will be sent back for display / personal use.
The successful candidate, upon making a comparable blade - may be provided with an exclusive North American arrangement to buy more product for use in knives.
I have a NOS knife to make the comparison against, it's return is not negotiable as it is from my personal collection with too much sentiment attached to it.
TESTING
5/8" rope cutting - how many cuts before it goes dull. If it won't cut paper, it's dull.
Metal table torture - rap the edge of the blade 5 times. Inspect for damage to edge either in chipping or edge rolling. The blades should not break.
Corrosion - clean the blades with window cleaner to remove any oils that may protect the metal. Wipe dry and rub citric acid (lime or lemon) on both sides and repeat for a few days without further washing.
If that's not enough, we could do something with saltwater or leave in a brine tank for a week.
* Delete if not allowed *
7/1 Updated for clarification of terminology. Added test information.
TESTING
