- May 21, 2000
Since I started making knives, I've tended to focus on small to medium sized knives as they are generally carried more frequently than their larger counterparts.
However, I've recently started working on considerably larger defensive and utility blades. While the processes are the same, making a large blade takes quite a bit longer than a smaller one. Your techniques really need to be established, or you'll end up ruining a bar of steel.
This new design is my idea of a fighter/utility/chopper blade. I still haven't named it! I think that many elements that make a blade good for utility purposes translate well into a defensive role.
I've designed the blade so that it will be lightweight relative to the overall size, yet still have a bit of mass for chopping.
I may include a sharpened swedge so that back cut techniques can be utilized; I haven't decided yet. Either way, the point will still be capable of excellent penetration. Most blades of this type have very poor piercing capability, something I'm going to avoid on this model.
The blade will be hollow ground with a 14" contact wheel. This results in a fantastic edge geometry that is still quite durable.
Since this is a new model, I'm still debating certain aspects of the design.
I'm hoping to rough grind and heat treat this tomorrow, and will do my best to share pictures along the way.
Looking forward to any feedback you might have!
Specs as planned:
- 18.5" OAL, about 12.5" cutting edge
- Slightly oversized 3/16" 1095
- Will probably go for 58HRC
- G10 handles
Specs as planned:
- G10 handles
