Kailash Blades
- Nov 21, 2015
Our 15.5" mutiny is one of our most popular knives and has been instrumental in us earning the reputation that we have.
With this said though, the 14" version has developed a bit of a following in bushcraft circles. In these certain applications trading off the higher end of the chopping power for something that's lighter, more compact and a touch more precise and controllable in smaller chops has allowed for it to cement itself as a great one tool option.
With all this said the pattern we've been using until now has been one that's been freestyled by the blacksmiths and while it's done the trick we thought it deserved a little more love. This new pattern is a fair bit more refined, really emulating the proportions that gives it the performance known for and bringing across more of that unique styling.
A slender, gentle curve allows for a lot of speed and agility for brush clearing. However compared to a sirupate though the broader belly gives a bit more heft to keep it a competitive chopper.
This particular blade has steel hardware, a horn handle and a polished finish. This is one of the cheapest and classiest looks for a traditional khukuri IMO. Horn has earned a bit of a reputation as a poor user and something best kept on display blades due to it's slipperiness and uninviting feel. On the contrary,I'd say this is an issue with any highly polished material, it's just that horn is sually highly polished to bring out it's beautiful lustre and it isn't often experienced in a more raw form. When given a sanded, satin or raw finish the material feels warm and smooth with a soft traction to it.
The fuller cuts out weight while keeping a thicker rigid spine. The main grind is actually hollow in the upper portion for a deep bite, then convex at the edge for durability. This is a key part of why the mutiny and pensioner are both such high performing khukuris- a very steep, semi hollow main grind.
SPECS:
14" blade
6mm spine at bolster
430g
Prices starting from 143 usd.
Thanks for taking the time to read!
So for those of you that use khukuris in outdoors situations- how big is too big?
Or with khukuris are you only limited by your ambitions?
Take care,
Andrew and the team at Kailash.
SPECS:
14" blade
430g
Take care,
