- Jun 24, 2013
Hi, our dear friends in blade forums, the following are our new releases in November. These are our regular versions, which one would be your pick?
Knife model: Towser K
Designer: Azo
Specs:
Blade Steel: 154CM
Handles: Blue Richlite/Red Micarta
Blade Thickness: 0.13''/3.2mm
Blade Length: 3.4''/86mm
Overall Length: 7.95''/202mm
Weight: 4.27oz/121g
This is the first model we tried to use Richlite, which is made from 100% recycled paper. We've done experiments on these new handle materials and the results turn out really good. It is waterproof, durable, and ultra-lightweight. The cherry on the cake is that hexagon patterns could allow you to have positive control over this monster!
Knife model: Rapids
Designer: Carlos Elstner
From Carlos's design philosophy, he strives to design a knife with simple design language. Comfortable and functional features are the priority in his consideration. One of the good design elements that could have your attention is that we apply a semicircle on the spine instead of the straight line jimping.
SPECS
Blade Steel: 154CM
Handle: G10 + Micarta/G10
Blade Thickness: 0.15''/3.0mm
Blade Length: 3.46''/88mm
Overall Length: 8.03''/204mm
Weight: 3.46oz/98g
Knife Model: SS1
Designer: Imkee
SS1 is the first knife design from our former coworker Imkee who is a lovely, warm-hearted, and approachable girl.
She collaborated with Azo, a designer of a lot of amazingly great knife designs, to name a few, Begleiter, Domin, and Infinity, to work out her dreamy knife from her experience after working for Kizer for over 5 years.
Specs
Model: V3603C1
Blade Steel: 154CM
Handles: Purple G10
Blade Thickness: 0.12''/3.0 mm
Blade Length: 2.835''/72 mm
Overall Length: 6.65''/169 mm
Weight: 2.328oz/66g
Knife Model: Zip Slip
Designer: Michael Vagino
A little tweaking to the Zipslip makes it finally perfect!If you are already a fan of ZipSlip, don't hesitate to get one of these black stripes micarta Zipslip. The blade material is upgraded to CPM 4V, offering you extreme toughness while the stripe micarta handle scales make it stand out in its lineup.
Specs
Blade Steel: CPM 4V
Overall Length:6.83"
Blade Length:2.84"
Cutting Edge:2.375"
Blade Width:0.88"
Blade Thickness:0.12"
Blade Style: Drop Point
Handle Length:3.99"
Handle Width:1.00"
Handle Thickness:0.46"
Weight:3.16 oz.
Knife model: PPY
Designer: Azo
PPY retains all the upsides with an even sleek and elegant design. The red Micarta bolster gives a nice contrast to the grey micarta handle scales while the modified Zulu/Spear point 154 CM blade could be your great helper for daily tasks!
Specs
Blade Thickness: 0.11”(2.8mm)
Blade Length: 3.27” (83mm)
Overall Length: 7.44” (189mm)
Weight: 2.86oz (81g)
Knife model: Converse
Designer: Azo
Specs:
Blade Steel: 154CM
Weight: 4.27oz/121g
Knife model: Rapids
SPECS
Blade Steel: 154CM
Weight: 3.46oz/98g
Knife Model: SS1
Designer: Imkee
Specs
Model: V3603C1
Blade Steel: 154CM
Handles: Purple G10
Weight: 2.328oz/66g
Specs
Blade Steel: CPM 4V
Blade Length:2.84"
Cutting Edge:2.375"
Blade Width:0.88"
Handle Length:3.99"
Handle Width:1.00"
Weight:3.16 oz.
Knife model: PPY
Designer: Azo
Specs
