Price is $300 ea (shipped within CONUS). If you live outside the US, I will contact you after your order for extra shipping charges.
Bdz-1 steel is essentially 14c28n iirc (or one of the Sandvik steels). Just from another steel company. It's a lil better in edge retention than the 420hc the original strong arm has. And iirc it also has a different tang or a full tang. I forgot how the marketing went, as well as a different blade.
Should be slightly better overall but also more expensive.
This is a new version of the strong arm. I'm not sure if it's replaced it or not.That is interesting. Do you have a credible link to more information on the source/details around BDZ-1? Hadn't heard of it, or the notion that it's same recipe as 14c28n. For some reason I thought the strongarms were being made in the US and in Gerber's flavor of 420HC.
Composition (Nominal):
0.60/0.75 C, 1.00 Max. Mn, 0.025 Max. Ph, 0.01 Max. S, 1.00 Max. Si, 12.50/13.50 Cr, 0.75 Max. Mo, Bal. Fe
A martensitic steel chemically balanced and processed to provide a uniform, fine carbide structure. This structure has been suitable for the manufacture of thin sections and fine blanking operations. The alloy can achieve a tempered hardness capability into the low HRC 60’s.
CTS BDZ1 alloy is an excellent candidate for razor and utility blade applications, which demand high hardness and edge retention. This proprietary alloy is part of the CarTech CTS family of alloys, offering superior edge retention and surface finish and an ability to be machined to a fine edge and consistent heat-treatability from lot to lot.
This alloy is subject to decarburization during thermal processing. Take precautions to control this condition.
I didn't really look much but here's onecan't find many reviews
Via Gerbers websiteThe regular strongarm is already full length tang
maybe they just mean it's made of Bdz-1 now or maybe it's upgraded design wise. Dunno.This proven fixed blade offers an upgraded full tang, fine edge blade, now made of BDZ-1 steel. Also featuring a grippy rubberized diamond-texture grip, this is a knife you can bet your life on. The MOLLE-compatible multi-mount sheath system offers optimal customization, keeping your knife ever at the ready in combat situations.
Product will ship 11/17
Via Gerbers website
