- Apr 20, 2019
Hy guys
Today I finished grinding a rigid boning knife, in niolox+, new version of niolox, which should have a moderate tenacity and good edge hold. Tomorrow I would have liked to harden it but, having read the datasheet, I was a little perplexed. In the very short steel description it refers to "edge holding", which makes me think that the recommended heat treatment is for knives or cutting blades, and not for bearings / molds or other heat treatments that we are not interested in ... So I wonder, why they recommend a tempering temperature between 720 - 790 ° F ?? somewhat strange temperature range in a stainless steel, as it should reduce corrosion resistance. However I would like to obtain, a final hardness of 58/60 hrc if POSSIBLE. what HT do you recommend?I can sub-zero treat if is necessary.
https://www.lohmann-stahl.de/fileadmin/redaktion/downloads/1.4197.pdf
Tanks
Tanks
