Posted this in general discussion first and it was recommended to post it over here. My situation is this - I ordered an received the Ontario Kukri from Amazon and was unimpressed by the uneven grind on the blade. The right side is uniform and appears perfect, but the left side of the blade has more material removed (actually notched in a little at the top rear) and there is an area about 2/3 up the blade where too much material was removed making a slight wave/depression. At first I thought the blade was bent, but the right side is perfectly straight, so I realized it was a problem in the manufacturing. I exchanged the blade with Amazon and the replacement is identical. Is this normal for this blade? I'm torn as to whether I should keep trying for a blade without these issues, or give up and get the Condor Heavy Duty Kukri. I also don't know if my expectations are too high and this type of poor manufacturing is normal for this blade. Am I being too picky? I did a lot of searching but didn't find others discussing this. (To be clear - I'm not talking about the edge bevel. That's a bit wonky at the front of the blade and left side too, but I can deal with that. I'm talking about the actual blade grind on the left side.)
