- Mar 31, 2022
Okay, so I know my next two khukuri will be an MK-1, mostly using the default options, and a Mutiny. I'm leaning toward a 14" Mutiny but might go with the default 15.5", I'm not sure yet. The options for the Mutiny are mostly where I need advice:
First off, is the dark brown, chocolate micarta still an option? If so, do I configure the order with black micarta (for the price option), then request chocolate in the order notes or do I send in the order with black micarta then email someone to request the chocolate?
Next, the acid wash finish: the "in hand" pics of the Regent Long Knife show a much darker, mostly uniform finish then the rest of the pics that show a lighter blade. Is that the acid wash as I'd receive it or is it a natural patina? Is it possible to request an overall patina like that or just the hamon line and then let the patina develop naturally?
For the MK-1: I was surprised that the default grind is Performance, I expected the heavy chopper to default to Standard grind. Considering I'd be more likely to use this one closer to the ground (and possibly rocks), would I lose much cutting performance by going with a Standard grind to protect the edge? I'd most likely also be carrying my 7" Mini, so finer cutting or carving would be covered. Would the acid wash be out of place on an otherwise historical build?
As much as I really want to order both now, I'll most likely order the MK-1 first and wait on the Mutiny until I'm more sure which options I want there.
Thanks,
Jack
Thanks,
Jack
